does anyone hav a diagram of where to put oil temp sender adapter on cylinder three ?? and water temp sender too...
you got to strip off the inter cooler to get to it
i just ordered a oil filter sandwich plate as the oil temp and pressure senders fit right into it alot better to install
with no strippin down
Getting the temp from above cylinder 3 gives you a higher temp reading as that's where the engine is warmest. I asked around for some advice and was told that was the best place to put it. I can't find the instructions I had for it, but I think there was a guide over on NASIOC. IC off, find the oil gallery, install the oil gallery plug, screw the sensor into that. Certainly the way it works on a new age.
