ecu problem help
i fitted a scoobyecu to my ecu everything works great up until 4k rpm and it hesitates really bad on full boost
i have try the scobbyecu in to ecus just incase it was that still the same problem occured
now when i bought the scoobyecu i asked for it to be mapped for a decat and airfilter
i do not have the decat fitted could this be the cause of the hesitation (turbo spools up but the standard cat is blocking the flow of the gases causing this hesitation )[:^)]
 any advice would be most welcome
i have a jdm wrx 1995 saloon
I would have thought the chip supplier should be sorting this out for you ?
I'd try closing in your plug gaps to 0.5mm, if this improves or fixes it then the underlying issue is your coil packs need replaced.
cheers
Andy
