Boot lock jiggered, advice ?
Ok here it is . Was in the boot and seen this wee flip switch marked cancel on the lock mechanism so like the "don't push button" I flicked it. Surprise surprise the remote release no longer works !!! D'oh school boy error !!!
 No hastle , I'll use the key , yes? No! Fecking boot lock wouldn't turn and is now half in/half out the boot !!
 So , where do I go from here , is it possible to open the boot if I remove the lock altogether? Unfortunately I don't have split rear seats! :D
Try squirting in some penetrating fluid like 5 in 1 this is normally really good at freeing of the gunk inside the lock which after a while of soaking andd working should free it off.
All the rear seat bolts are in the main cabin if its a clasic im not sure ,but if its a newage ther is  6 bolts and thats job done.
Higgy
Had exactly the same problem, just squeezed through the wee armrest hole.
Had to no eat for a few days to manage it though !! lol
Or find someone really small that will fit through the hole behind the arm rest
I know a man that can do that..[:D]and made a wee vid about it.[:)]
 You can remove a speaker from the rear shelf and get in to unlock the boot by opening the lock. The small hole directly above the lock can has a lever which if you move unlocks the boot.
I had the same problem when I bought mine except that some ned had tried to get into the boot so it was totally bu**ered.You remove the lower part of the back seats with the 4 bolts that hold it to the floor then there are 2 bolts that hold the back part on,once removed push the back up and it should them come out,then all you need to do is climb in and put the switch back.I got a new boot lock and key off flea bay for 6£ posted.
Mine is a MY93 4 door so should be the same
Pete
Pete
Thank you very much Pete ( and all who replied). Used above method and its all sorted now ! Thank fuke !!! :)
