the blue dragon Posted January 10, 2007 Posted January 10, 2007 need some help /advice re my terzo. as ive not been a scooby owner for long im not really in the know regarding sourcing parts etc, Im looking for new seats for the scoob, and would like to stick to original subaru ones. where can i get these at a reasonable price? my ones are lookin a bit knackered and want to replace them asap. also having problems with water gettin into my boot, i think it may via the spoiler, what can i use to seal the spoiler ?? any help/advice greatly receieved. thanks iain [*-)] [Y]
st3ph3n Posted January 10, 2007 Posted January 10, 2007 I had water ingress in the boot from the brake light cable hole after I changed to the GT Wing. I solved it with a bit of double sided foam tape on both sides of the boot to cover that hole. I was also getting very small amounts through the bolt holes themselves due to the washer setup, so what I did was get some rubber plumbing washers and used them too. That solved all the water problems in the boot. For your seats - ebay is a good hunting ground, but the specialist Subaru breakers will be worth a look. I can't for the life of me rember the names though. Give the search a bash and see if it turns anything up.
the blue dragon Posted January 10, 2007 Author Posted January 10, 2007 many thanks mate, ill try that re boot and also try looking for specialist breakers, any idea what will fit a 98 terzo, as in direct replacement, if im looking for seats from a classic?
diffbuster Posted January 10, 2007 Posted January 10, 2007 Water in boot is generaly caused by light clusters having been removed and replaced without sealing, if resealing use silcone which doesnt set hard or they will be a pain to get out next time i learned the hard way.
