hi need advice
Can't complain about the Prodrive springs for the car. Doesn't lower it that much, but the changes to the spring rates transform the handling, and doesn't impact on ride quality (actually improves it slightly under mst circumstances!). They are made by Eibach to Prodrive specs (which are different to Eibach ones available directly).
Available from your friendly Subaru dealer. Think the cost is around £180.
John
A might be wrong, but i dont think the springs are inclued in the PPP. I think that inlcudes an exhaust system and remap, not sure what else tho.
The PPP is an exhaust change, a high flow sports cat downpipe, a panel filter and a replacement ECU.
You do not get the springs included am afraid[:)]
dont see what all the fuss is about with the PPP`s TBH, you dont exactly get alot for yer money really
Totally Agree Ac!d
But when its free, then its free[:)]
But then you see what happens when you spend UNDER the 2k that they charge for PPP, on the same car Yeee Haaa[:D][:)]
Totally Agree Ac!d
But when its free, then its free[:D]
yup money well spent there lolz [:)][:D]
If your car has the PPP fitted, then there is a chance that your car may already have the prodrive springs fitted. Check the colour of the springs you have on your car. If they are red in colour (might need to scrape off the mud and dirt!), then you have the prodrive ones fitted. Black = standard springs.
John
John
cheers. will go have a look now
