cusco kid Posted October 19, 2006 Posted October 19, 2006 hi guys would any of you out there be interested in a group buy of TEFLON ?100% pure engine additive.PTFE is minute balls of poly tetra fluro-etheline forgive the spelling / PLASTIC. i can get the teflon 100ml that can be pre mixed with your engine oil or supplied raw or with a carrying fluid that wont effect your oil/I used to be sponsored by a teflon companys in the 1990s, we used it my 350 bhp 3 door engine, gear box , and / diff ,teflon greases in hub brgs/ i used to run a diff cooler along with a JABSCO pump- pressurising oil on to the CWP to keep it cool.I had a temp sensor in the diff and saw a lowering of about 10 degrees during eventsI also used it in my next 3 door 4x4 inc transfer box. Many of my other competitors suffered failures running less power than me, My fleet of police cars and skid pan cars also benifited from the additives. Anyway i can get it in sealed bottles for£ 10 for 100ml that is the correct dose for 4 to 5 litres ideal for turbo, cars IT will mix with any oils Can be used to upgrade a cheeper oil. It can handle extreme temps and pressures and is avail/ for g/boxs diffs at same price IF YOU ARE INTERESTED OR WANT ANY MORE INFO CONTACT ME[]regards geo
cusco kid Posted October 19, 2006 Author Posted October 19, 2006 hi only silicone type/[H] not plated or auto boxes its a lubricant
craig mac Posted October 19, 2006 Posted October 19, 2006 Is that not just the same as the good old Slick 50 i used to through in to the old cross flows? CraiG
cusco kid Posted October 19, 2006 Author Posted October 19, 2006 hi you cant class this teflon with slick 50 the later was 90% carrying fluid 10% regraded teflon ,this 100% pure manufactured teflon from DuPont of holland mixes with all syn/oils mineral oils. the micronic sizes of the balls differ for engine,the smallest type is used so it can pass through your oil filter this lubricant lowers friction /temps keeps oil cleaner,and aids fuel consumption[] and prolongs oil life
cusco kid Posted October 20, 2006 Author Posted October 20, 2006 never heard of them only got exp/ of teflon as used by me in motorsport and my police cars geo[au]
dipsy Posted October 20, 2006 Posted October 20, 2006 Those two additves have websites .About the products
