possible boost holding problem
Guest
hi folks,
our classic wrx is having a wee problem, tried to resolve before. well driving normally it will hold 0.9 bar boost in all gears BUT when you nail the car it goes to 0.9 bar --- then has a big backfire, seens as though the anchors go on, boost drops to 0.6 bar.
the coil packs, plugs, oil levels are okay, car running on shell V.
does anyone - grant, et all have a clue why its doing it .......... a bit hacked off.
thanks
hi folks,
thanks for the replies, net access is limited at the min.
J6R - the boost does return to 0.9 bar.
When i first got the car - 2 years ago it had a new maf (courtisy of the squirrel) - and even at that point it was doing the same, thats when the coil packs were changed. at that time it has an hks induction kit on it. i sold the catr to pedals who swithched the induction kit to a std filter. since getting the car back it still had the 'backfire' problem.
i will check all connections etc when i get a chance, if all ok what else could it be?
thanks again folks.
looks like it could be similar to what pedals found on the car, one hose loose, will check it out.
keep you posted.
well all pipes are on okay, maf looks ok ..... so where now.
is it a new fuel pump? or is it a case on not nailing it and puting the power in smooth, until i can get plan b done (apexi)
