seafar99 Posted August 26, 2006 Posted August 26, 2006 Anti-freeze and water, but better have a check to see where your coolant has gone.Any leaks?
hammy Posted August 26, 2006 Author Posted August 26, 2006 cheers mate just the stuff you put in your wind screen washers i will have a look for leaks aswell cheers again
seafar99 Posted August 26, 2006 Posted August 26, 2006 wind screen washer bottle tank ....=......water radiator/coolant system.................=......water/anti-freeze mixture
hammy Posted August 27, 2006 Author Posted August 27, 2006 its not low well it was but not now somethimg going on its full now ????????????? and no leaks???????
z1000 Posted August 27, 2006 Posted August 27, 2006 Should only check it when its cold i:e first thing in the morning. Don't take the cap off when its hot or you'll burn urself silly. Ur local friendly garage will probably check ur antifreeze mixture free if you ask.
thefastone Posted August 27, 2006 Posted August 27, 2006 Is this your first time checking your levels in a car mate.... [] [] Nah, but seriously its somthing that every Driver should know, again somthing else that perhaps they shoudl be teaching in your driving test.... Also, It shoud tell you in your drivers manual....[]
Anonymous Posted August 27, 2006 Posted August 27, 2006 What model year and why do you think level is low?
