Car Cleaning Question
ive only used it once , from what i saw it removes all the little bits
of grit tar and bits of s**t thats stuck to the paint , all the rough
bits you usually find behind the wheels can usually be removed with
clay bar but be careful how you use it as you can end up making a mess
of yer paint job
Comes with a bottle of detailer to spray on and its fine and easy to use as long as you keep the paintwork wet.
I was amazed how much difference it made for how little effort.
BE WARNED , if you drop the clay on the ground when your using it chuck
it in the bin right away , what will happen is if it makes contact with
the ground little bits of s**t will stick to it and when you use it
again the little bits of S***t thats stuck to it will make a mess of
your paint ie/ lots os swirls and scratches
Where can I buy a clay bar tomorrow morning...?  Might do Julie's car tomorrow afternoon - it needs clay bar'd before I put the Klasse/Carlack 68 on it & some proper wax.
Brian [:o]
I got mine from polished bliss , just thinking brian i saw the Meguairs
stuff  (same stuff sold by richard at polished bliss) in halfords one
day this week , they had a whole stand full of Meguairs stuff on
display
Halfords in Straiton it is then!!!  Cheers Martin.
Was going to order the Meguiars Cly Bar/Detailer from Polished Bliss the other week but they were out of stock.  Should have got it from eBay.  Oh well...
Brian [:o]
