4Hero Posted July 6, 2006 Posted July 6, 2006 Good morning, My check engine light is on permanently when you boot her up. It stays on and doesn't blink. HELP Any ideas what this means [] I've got a 53 plate wrx. Thanks in advance!
st3ph3n Posted July 6, 2006 Posted July 6, 2006 Neil, take it somewhere with a select monitor and they should be able to tell you what the fault code is, and indeed what that fault code relates to. Any of the dealerships should be able to hook it up while-u-wait if they're nice. Failing that I could plugin my R-Vit and see what it coughs up as it supposedly reads the ECU fault codes. Only takes 2 minutes to do. You'd need to get a list of codes though as it only tells you the number, not what it actually means.
irish al Posted July 6, 2006 Posted July 6, 2006 Have got the software to read CEL faults. I touch goats.
4Hero Posted July 6, 2006 Author Posted July 6, 2006 Thanks guys, I just called nobles and am about to head down just now. Glad I still have 6 months warranty []
