Help Tarox Brakes
Trying to take the pads out for id purposes and to scallop the outside one which is rubbing against the hub  but can only get the top and btm bolts out (the ones which go through the pads ) the larger middle bolt (could have sleve ) which hold the two billets appart is absolutly solid have tried tapping with hammer, wd40, no movement. This bolt does need to come out to allow the pads slide out doesnt it?
Any suggestions ?
I hate mechanical problems...
Never worked on those specifically but i would say unbolt the caliper and take them out the front as i presume the pads are now loose with top and bottom pins removed.
Got them done. Thanks for the idea to remove the whole calliper. All the studs and nuts were totally covered in lock tight and being alluminium they are easily damaged. Away for a test run now that the footies over.
