Quick techie question..... Spark plug gaps for mine
Just taken delivery of some lovely new Iridium spark plugs... now bearing in mine I am running between 1.0 and 1.4 bar (adustable) what is the recommended plug gap ?
Or what are yours set to ?
A big fat 1.1mm was recommended for the standard plug so i would guess it would be the same for uprated plugs plus if your running higher boost than normal you will need a fatter spark to cope with the higher combustion temps/pressure.[H][H]
might be 0.9 maybe but i cant remeber bigger gap = more likely higher boost will blow the spark out, search scoobynet or search sidc i did my sparks a while back
It also depends on your coil packs how good  they are. If you are running more than std boost ei 1.4 bar  you need a smaller gap normally about .8mm if your coils are ok if they are old then you may get a misfire on boost in which case you make the gap about .5mm but this can cause a rough  idle.
Thanks for your responses... in the SIDC FAQ it states 1.0 - 1.1 mm for standard ones... here >
I've read that you cannot adjust iridium plugs for fear of snapping the electrode.... mine are pre gapped at 0.7mm I have a 1998 UK spec with the coil pack at the top on the inlet manifold.
Back in the days of my cosworth, the higher the boost, the bigger the gap and the bigger the coil.... but my coil pack is all integrated...... hence my dilema
