header help
I have megan headers that are a all in one unit header and up pipe with a flexi joint at the up pipe wrapped mine they work great for me, not the techie minded [:$] so could not tell you whats the best or if there will be any performance difference's at all.
I sure the more techie minded guys will be along soon and should be able the advise further [;)]
Wrapped and solid.
Ok you may need to re-wrap in the future, but your a bit stuffed if and when the jet coating comes off and end up wrapping anyways.
Soild, as you don't need to worry about the flexi breaking up. Less restrictions in flow, too.
Solid with expansion joints in both the headers and uppipe.
Make sure the expansion joints work when you put them on as
mine probably didnt and they ended up cracking at the flange.
Dropped my heatwrap in a bucket of water this time before wraping
and it was much easier with less loose fibers. Also gets tighter when
it dries out.
Al
been looking at a set from flat 4 that i might go for, athou i could get a cheap set from the US but they might be poor quality. anywhere cheap for heat wrap, and how much will i need?
ta again
I got the Gruppe S header and i think they are not bad...great performance and noise is out this world plus your car will be quieter at idle and loud as feck when giving it some.
its the gruppe s ones on fllat four i m looking at, if i get the un coated ones how much heat wrap would i need, as its only an extra 25 quid for the coated
Coated headers are very expensive, the only coating worth considering is ceramic and that is very expensive indeed, over 800 last I looked. 100 will see them wrapped properly with proper lagging.
Flexi joint IMHO. You need a bit of give, Ive seen the solid HKS ones crack and Ive seen crap fexijoint blow after only a few thousand miles so do your research.
Callum W
OK ordered the headers, any idea how much wrap i am gonna need?
sorry for all the questions
and paddy how much to fit them[;)]
