bigdavie Posted March 7, 2006 Posted March 7, 2006 if so please help me !! had a look under the cowl and cant find anywhere to plug it in ??!!!!! can anyone help ?? either by reply here or in person or piccies !!???? anytyhing at all greatly apreciated !! ty
dave_morgan Posted March 7, 2006 Posted March 7, 2006 I fitted a Blitz one to my P1. You need to buy a wiring harness with it, which effectively just splices into the ignition circuit. Fairly straight foward to fit, if you've got the wiring bit. Dave
bigdavie Posted March 7, 2006 Author Posted March 7, 2006 yep got the wiring loom with it for the classic is it just a case of matching the wire colours up as i thought it plugged in somewhere ??!! cheers!
Highlander68000 Posted March 7, 2006 Posted March 7, 2006 You need to get your heed right under there. (A torch is handy too). IIRC it's a large white connector and is likely to have the thickest wires of the bunch on them. On the ones I've fitted (I bought a job lot once and fitted many too) , the connector was slightly to the right of the steering column centre. It is easy to reach and easy to unplug too.
dave_morgan Posted March 7, 2006 Posted March 7, 2006 The wiring adapter harness you have should have 2 plugs on it - a male and a female. Find the similar looking plugs under the dash (you'll need to take the steering cowling off) and unplug them, then plug the wiring harness in between them to complete the circuit again. Am I making any sense? The plugs you undo will lead to the ignition barrel. Dave
Highlander68000 Posted March 7, 2006 Posted March 7, 2006 (you'll need to take the steering cowling off) Dave I've never had to on the harnesses that I've had.
dave_morgan Posted March 7, 2006 Posted March 7, 2006 (you'll need to take the steering cowling off) Dave I've never had to on the harnesses that I've had. Hmmm, you could be right!!! I took mine apart so I could route the cables through and tie wrap them to appropriate places so they weren't flapping around. It's only 2 screws IIRC. I mounted my TT on the little ledge just under the speedo/tacho etc., so taking the cowling off made this all easier. I guess if you can see the plugs I refered to earlier, and you can route without taking the cowl off, then feel free!
dave_morgan Posted March 7, 2006 Posted March 7, 2006 You need to get your heed right under there. (A torch is handy too).IIRC it's a large white connector and is likely to have the thickest wires of the bunch on them. On the ones I've fitted (I bought a job lot once and fitted many too) , the connector was slightly to the right of the steering column centre. It is easy to reach and easy to unplug too. Didn't realise you'd posted here too, but yep, you need to get upside down with your head near the pedals to see what you're doing properly!! Torch is definitely recommended as you say !!!
bigdavie Posted March 7, 2006 Author Posted March 7, 2006 wow so many replies !! thanks very much guys will let you know how i get on tomorrow much apreciated !
scoobykev Posted March 7, 2006 Posted March 7, 2006 And make sure the wire is connected to the handbrake switch so you can't drive off with the key out of the ignition. Like i did[:$]
dave_morgan Posted March 7, 2006 Posted March 7, 2006 LOL, yes very important Kev!! A bit more secure that way too!
