baz bolton Posted July 22, 2003 Share Posted July 22, 2003 i drive a 97 type ra. the problem is it has just started to leak water from what i think is the header tank.(left hand side if engine) can anyone shed any light on this problem. thanks baz Link to comment
CAZ1562 Posted July 22, 2003 Share Posted July 22, 2003 Is the tank leaking ? If so from where ? It has been known for these plastic expansion header tanks to crack/burst. The cap can also leak. Hoses can go brittle and split. The more info you supply, the more helpful we can be Also easier if you have a digi camera to aid a solution online by posting up pic's of the problems you may be facing. I hope this helps you to help us help you Link to comment
baz bolton Posted July 22, 2003 Author Share Posted July 22, 2003 ok found out it is the expantion tank seal leaking . trouble is now trying to get hold of one.. mine is the black plastic type with crimped cromme around seal and top. anyone have one spare ??? or know where i can get one .? thanks baz Link to comment
kipper Posted July 23, 2003 Share Posted July 23, 2003 A dealer should be able to order one in m8, if not you could try grade A on 01663744114.. Link to comment
CAZ1562 Posted July 23, 2003 Share Posted July 23, 2003 Baz, Try & get an alloy one from later models and modify the existing one or I'm sure some company have made alloy header tanks for direct replacements to the black plastic one's. Scoobyworld Link to comment
