Dave K Posted January 26, 2006 Author Posted January 26, 2006 Went down last Sat to sort out a service and he had just finished loading the last truckload, so this week is his first in new premises. Was told it is a rototest dyno don?t know if 2wd or 4wd, but would imagine it would be 4wd due to most cars through there being imprezas and evo's. I agree with you re the cost.
Cret Posted January 26, 2006 Posted January 26, 2006 No idea dude, just when I was up the rally at Jurby just after a Chrimbo a certian scoob oriented bod up there said he already had his new gaff and had a 2wd dyno. Who knows but fingers crossed its a 4wd one so that when I think I have mine close to the mark I can get it checked. Will he have anyone there that's capable of doing mapping etc?
Dave K Posted January 28, 2006 Author Posted January 28, 2006 Went down this afternoon to book the car in for a service, very nice setup. Dyno room was still being painted, mid march for the gear to go in.
pobiom Posted February 3, 2006 Posted February 3, 2006 Dave did you manage to fit the lower strut brace you bought ? how difficult was it ? and how do you do it with not having a lift etc... ?
Dave K Posted February 4, 2006 Author Posted February 4, 2006 Quote Dave did you manage to fit the lower strut brace you bought ? how difficult was it ? and how do you do it with not having a lift etc... ? No not yet, I have access to a lift so may be doing it soon or I may get Paul to do it when next in for a service.
Dave K Posted February 4, 2006 Author Posted February 4, 2006 Quote So is it going to be 2wd or 4wd then dude????? doh[:$], I didn't think to ask. I'm sure it will be 4wd, and even if it’s not initially all they have to do is buy 2 extra units to make it 4wd.
Dave K Posted February 4, 2006 Author Posted February 4, 2006 (edited) Fuel pump replacement Remove rear seat; Remove sound deadening; Then remove brace bar, only on Type R/Ra's AFAIK as this is classed as the solid rear bulkhead. Also remove rear board; I then disconnected the battery, as we don’t want any sparks with fuel all over the place. Next remove the four screw's holding the access plate; Then proceed to remove the fuel lines one at a time, this can get messy so have plenty of cloth ready to catch the fuel. Also leave the car for about 2 hours after driving before doing this to allow the pressure in the system to subside, don't make a big difference but helps with excess fuel. Remove all the retaining nuts on the tank access plate. Then to remove the pump assembly you have to lift and twist it out, you also have to pull the float up before it will come out. As can be seen the old filter sock is full of contaminants from years of use. Just to add I replaced the OEM fuel pump over a year ago and the general consensus on most forums was to keep the OEM filter sock as the one with the old kit was to small; However the new kit comes with a filter sock the same size as OEM ; Next follow fitting instructions included in kit; I added a zip tie on the body of the pump to stop it moving as an extra precaution; Then reverse the removal procedure, when all connected up don’t start the car straight away, turn the ignition on 2 or 3 times to allow fuel pressure to build in the system again and get rid of any air locks. Edited June 18, 2008 by Dave K
Dave K Posted February 16, 2006 Author Posted February 16, 2006 (edited) Well after swapping the fuel pump out there was nowt wrong with it as I suspected. Anyone need a walbro pump? The problem was due to the voltage issue I had with the ecu and yet an other faulty lambda sensor. So wideband it is and a new A-pillar pod; All fitted; Edited June 18, 2008 by Dave K
andrew_field Posted February 16, 2006 Posted February 16, 2006 Looking nice there Dave. So how many guages is that now?
pobiom Posted February 16, 2006 Posted February 16, 2006 Looking sweet dave ! If only i had waited, my 255LPH pump turned up yesterday for me to fit this weekend. Damn, should have asked you first, oh well any other parts let me know.
dooahhdoo Posted February 19, 2006 Posted February 19, 2006 Just out of interest dude where is the brace bar in the pics m8? As you know my fuel pump failed outside Tescos at 7:30 pm on a friday night. Only took 30 mins to change though so wasnt all bad but just wondering about the bar. Oh, sorry. Forgot to add........ TART! []
Dave K Posted February 22, 2006 Author Posted February 22, 2006 Quote Looking nice there Dave. So how many guages is that now? Lol to many![:$]
Dave K Posted February 22, 2006 Author Posted February 22, 2006 Quote How's it going Dave??? Fine thanks Bob, yourself? Well except for this ecu problem.[:@] But hope to have that sorted soon.
Dave K Posted February 22, 2006 Author Posted February 22, 2006 (edited) Just out of interest dude where is the brace bar in the pics m8? As you know my fuel pump failed outside Tescos at 7:30 pm on a friday night. Only took 30 mins to change though so wasnt all bad but just wondering about the bar. Oh, sorry. Forgot to add........ TART! Typical, don’t have a pic of it, but you can see where it is in the pic below. The line running across the sound deadening about half way up. Edited June 20, 2008 by Dave K
blue boy Posted February 22, 2006 Posted February 22, 2006 Quote Quote How's it going Dave??? Fine thanks Bob, yourself? Well except for this ecu problem.[:@] But hope to have that sorted soon. Fine Mate thanks, hope you get the prob sorted soon and don''t take too much stick from Nick!
dooahhdoo Posted February 22, 2006 Posted February 22, 2006 Quote Quote Quote How's it going Dave??? Fine thanks Bob, yourself? Well except for this ecu problem.[:@] But hope to have that sorted soon. Fine Mate thanks, hope you get the prob sorted soon and don''t take too much stick from Nick! Bob what do you take me for LOL Dave, I have got one of them as well dude
blue boy Posted February 22, 2006 Posted February 22, 2006 Quote Quote Quote Quote How's it going Dave??? Fine thanks Bob, yourself? Well except for this ecu problem.[:@] But hope to have that sorted soon. Fine Mate thanks, hope you get the prob sorted soon and don''t take too much stick from Nick! Bob what do you take me for LOL Dave, I have got one of them as well dude LOL!
Dave K Posted March 7, 2006 Author Posted March 7, 2006 Finally got me front mount IC spray to work this weekend. 2 none return valves inline and the nozzles dont drip.[] Just need to obtain a few more nozzles then whip the bumper off and mount them.
Dave K Posted March 15, 2006 Author Posted March 15, 2006 (edited) Got back to the rebuild at last after spending the last few weeks playing with the ecu trying to get the car drivable. Think it’s more potluck than mapping but it’s at an acceptable level now. Left it needing the compressor housing to be modified, so one hacksaw and some patients; Followed by an angle grinder; We have a cut down housing; As you can see a bit rough to start with; Then test fit the cut off elbow inlet; Needs inlet cutting down to size and then two half’s making flush fit ready for welding. Made a start on tarting the components up! First up actuator and water pipe; Edited June 20, 2008 by Dave K
Cret Posted March 16, 2006 Posted March 16, 2006 That's brutal Dave!! Don't think I could bring myself to do that to a turbo! All coming together very nicely though mate.
pobiom Posted March 16, 2006 Posted March 16, 2006 Looking good dave !! So ECU sorted now, when do i get a spin ?
Dave K Posted March 24, 2006 Author Posted March 24, 2006 (edited) Ecu is still playing up now and then, stalled at halt sign a few times yesterday. Moved on to tarting the exhaust housing and central body, all masked up and ready for some high temp paint; After it had dried; Fitting of oil/water pipes and clamp; Followed by compressor housing (unfinished) and actuator, dry fit; All I can say it better work after all this, no doubt it will look good covered in oil if it goes pop! So just the compressor housing to weld up and polish then fit it. Edited June 20, 2008 by Dave K
Dave K Posted April 20, 2006 Author Posted April 20, 2006 (edited) Been a bit slack over the last few weekends as have been getting back into racing the old bike. New purchase turned up today, going back to a 3" system for when the headers go back on so fitted it tonight; Need to get a 3" gasket as it is blowing at the moment. Silent it is not, and it should be louder once I mod it. Edited June 20, 2008 by Dave K
