TypeRA28 Posted September 28, 2005 Posted September 28, 2005 I have a turbo timer sitting in my garage, but have no clue how to fit it. I phoned Blitz for instructions, but they said it was a UK product that I have, so couldn't help. Would anyone have a set of instructions. I bought it off ebay, hence no instructions with it.
dave_morgan Posted September 28, 2005 Posted September 28, 2005 Depends on the model, but you should have also got a wiring loom with it for the scoob. Very simple to fit. You just crawl under the dash and find the wiring loom going to the ignitiion switch, find the plug that matches the one on the turbo timer, unplug it and plug one plug into one end of the turbo timer and the other plug into the other end of the turbo timer.That's it !! (and mount it somewhere obviously) It may also have a boost gauge built in. In which case you can run the vacuum tube through from the engine bay and 't' it into your boost hose. If you're local to Edinburgh I can show you what needs done, but haven't really got the time just now to do the job for you I'm afraid. What model is it? If it's the same as mine you're welcome to come and have a look. Dave
TypeRA28 Posted September 29, 2005 Author Posted September 29, 2005 Hi Kart man. It's an MY97 WRX. I have looked under the steering wheel, but the conectors are different to what is on the turbo timer? Anymore suggestions? Thanks.
dave_morgan Posted September 29, 2005 Posted September 29, 2005 What model is it? You may just have the wrong loom adapter.
irish al Posted October 5, 2005 Posted October 5, 2005 Having the same problem with my turbo timer. The wireing loom didnt even come with it. Hate EBAY sometimes. Anyone know where to get a loom adaptor for a 2003 WRX. Have had a look on the net but no success.
