God Speed big disc conversion group buy
Have been talking to Ian at Godspeed with regards to his big disc conversion for Imprezta four pots .
Kit includes
We can offer this 335mm disc kit which retains the standard 4 pot calipers, which are a very good powerful caliper. The kit includes caliper spacers which widen the caliper to fit the thicker disc, caliper mounting brackets which bring the caliper out from the hub assembly which enables the fitting of the bigger disc, and larger than average pads which take advantage of the wider swept area on the disc.
The discs can either be supplied grooved, drilled or grooved and drilled. Due to the heat that is generated on the track, if you are going to take part in track days, we would recommend the grooved only.
The pads supplied can be either Mintex 1144 or Ferodo DS2500.
Price normally £625.00
If we can get 5 people then the price will be £575
10 people then the price will be £550
Please let me know of your interest below
Tony
