Handbrake Problem
hi need bit of help iv no hand brake but have replaced all discs pads shoes and cables everything is adjusted perfect when on lift wheels lock but when on a hill it rolls away any iders on what would cas this as im abit stumpt
glased drums. causeing brake shoes nae to hold tight by the sound of it. try some rough sand paper and roughen up the new shoes and rub up the inside of the drum.
:Wales-flag:
Edited by scottishtaffy
Pop the gromits off the back of the hub for adjustment.
iv got it adusted so that there is a drag on disc when hand brake if off but when u put handbrake on when wheels are of the ground it holds but on a hill it dont
If its new shoes and discs they will need to bed in then be re adjusted, I have seen a cable being tight at the front and the rear moving with no effect on braking being caused by the retaining springs being too tight on the backing plate
all springs replayed and all been on car 2 weeks now and cars driven every day and its the shoes in side discs
Where are u located?
The shoes need to bed in on the drum face as it is smooth to start with and the friction surface will rough it up
Edited by scoobywho
The shoes need to bed in on the disc face as it is smooth to start with and the friction surface will rough it up
kilsyth going go see hiyper tec on sat to see if they can help as need to go see them to see y it wont start some times just tho id ask on here first incase someone had the same problem and could of helped n could of fixed it my self in work
We are in bishopbriggs, plenty of rear impreza brake shoes done without problem, the poll has a spring over one end if that is missing it may cause the problem
ye iv dune them befor without any problem the sprins are there
The shoes may not be centering on the hub when setting, causing one to hold the bell when jacked up, but under the weight of the car give way.
  • 2 weeks later...
Agree we taffy whe discs r new thay come we a greasey fillm on the to prevent rusting I use thiners takes it off then ruff it up we sand paper or emery paper then gee the pads a wee ruff up to
