wrx kenny Posted June 6, 2013 Share Posted June 6, 2013 On way home from work tonight car hasn't even done 4 miles, my temp gauge went to red , pulled over water was pouring from bottom end of radiator and that burnt smell of water . Topped up header tank and expansion tank pulled off needle went back to just below red and started to gradually drop .oomed at water in expansion tank had gone quite murky with bits of crap in it , but no more leaks from the radiator area . Help , thanks for replies . Kenny Link to comment
thebigfelly Posted June 6, 2013 Share Posted June 6, 2013 Blow /crack in hose kenny? Or maybe somthings threw up and punctured rad?. Link to comment
scoobywho Posted June 6, 2013 Share Posted June 6, 2013 Was the water pressurised kenny Link to comment
scoobywho Posted June 6, 2013 Share Posted June 6, 2013 Could be a blockage in the radiator/hoses or worst case head gasket Link to comment
wrx kenny Posted June 6, 2013 Author Share Posted June 6, 2013 WhAts the signs if head gasket , the engine was brand new and only put in 20.000 miles ago hoping its not that Link to comment
scoobywho Posted June 6, 2013 Share Posted June 6, 2013 Coolant pressurising on boost and poring out the overflow usually, you can get a sniffer test done to find out, a radiator blockage can give similar symtoms without the exhaust gas in the coolant. But as been said before, check thermostat is opening correctly and water flow is ok, check the radiator cap isnt worn out, and also do a system burp then take it a blast and seeif it does it again Link to comment
wrx kenny Posted June 6, 2013 Author Share Posted June 6, 2013 How do I check the thermostat is opening and where is it , sorry for all questions Link to comment
scoobywho Posted June 6, 2013 Share Posted June 6, 2013 Its on the bottom hose the water should drop a bit when open Link to comment
wrx kenny Posted June 6, 2013 Author Share Posted June 6, 2013 Thanks ill check it in morning Link to comment
scooby222 Posted June 7, 2013 Share Posted June 7, 2013 hope its something simple Kenny! :S Link to comment
wrx kenny Posted June 7, 2013 Author Share Posted June 7, 2013 (edited) Car was taken to Ra in Perth this morning hoping its just the temp done the same thing again this morning and cold air coming through the vents . Kenny Edited June 7, 2013 by wrx kenny Link to comment
scoobywho Posted June 7, 2013 Share Posted June 7, 2013 Hope its not bad keep us posted kenny Link to comment
wrx kenny Posted June 13, 2013 Author Share Posted June 13, 2013 Car is in at Ra although they haven't been ae to look at it properly early suggestions its either the turbo or piston seals aaaaagggghhhhh. Kenny Link to comment
thebigfelly Posted June 13, 2013 Share Posted June 13, 2013 Aye saw the fb post kenny.. good luck with it Link to comment
g1983 Posted June 13, 2013 Share Posted June 13, 2013 Sorry to hear that Kenny. The labour of love is very trying Link to comment
