Engine Coolant
checked ma coolant level last nite its about 1cm above minimum, the engine was cool.
is this too low as i know it will expand when engine is warm?
if so which coolant should i get/use?
cheers for any replies :occasion14:
its the tank on the side kenny thats just above minimum, not checked the actual radiator as i assume it will be full as there is stil coolant in the plastic tank.
I would check it in the main header tank first and if its down in there top up first and then top up the reservoir.
Also what colour is your coolant? peachy pink or green/blue?......buy according to which it is :icon_salut:
ok cheers guys, i think its the peachy one.
