Somersetscooby Posted September 1, 2012 Share Posted September 1, 2012 Got a 2001 classic Scoob currently on my way to trax... Started hearing a strange knocking so stoped checked the wheels ect couldn't see anything so carried on then i came to a hill with traffic lights didn't need to keep my foot on the brake as wouldn't roll then she started to steam a bit checked the basics oil is fine waiting for her to cool down befor checking the water but there's a bit of a burning smell any help....? Link to comment
scoobywho Posted September 2, 2012 Share Posted September 2, 2012 Could be clutch release bearing, better get it checked incase it's the crank floating about Link to comment
Somersetscooby Posted September 3, 2012 Author Share Posted September 3, 2012 It's fine to drive so would that still b the crank..? Drove it back from trax an it was ok, the coolent tank next to the battery was empty. Thanks for the reply. Link to comment
scoobywho Posted September 3, 2012 Share Posted September 3, 2012 (edited) My classic started off making a slight clutch slip under hard load in every gear but on a brand new clutch, then started knocking on startup but quiet after 5 seconds. Changed the oil pump noise stayed. Was cruising along at 50 on the motorway and felt like it was vibrating. Pulled over and engine bay was cloudy with smoke. Recovered it home and found the crank had been moving up and down at the back and pushed the seal out and bottom end bearings and bits of conrod were in the sump had ran on the three good ones but not well lol Check the calipers as well incase it's just a sticky one and the steam was a coincidence Edited September 3, 2012 by Scoobywho Link to comment
Somersetscooby Posted September 3, 2012 Author Share Posted September 3, 2012 The steam was from the coolent bottle I no that much... As for the slight nocking with only happens very rarely comes from the passenger side was thinking prop shaft or the rear diff.... Link to comment
scoobywho Posted September 3, 2012 Share Posted September 3, 2012 Hopefully it's not too serious. I'm always worst case lol Link to comment
Somersetscooby Posted September 4, 2012 Author Share Posted September 4, 2012 Ye I hope so lol it nocks when u reverse aswell noticed this morning only nocks once.. going to the Scooby dealers an see about a full blown service Link to comment
