wheel alignment/tracking...
As usual wi 70% of my posts wee bit of advice or help.
Got a flat tyre on front passenger singer. Put on a replacement tyre and wheel i had in the garage. Same size of tyre as the rest and alloy. But now cars pulling to the right and even worse when acelarting wont even mention what its like when the turbo kicks in only happened since i replaced this
So obviously first thot is tracking and wheel alignment.dont wana put it in the garage and get this all done if its not the case so just wanting vit of reasurance that my first gues is correct.
More than likely the wheel you put on may be buckled or something like that, try another one from somebody and see if it eliminates the issue, if not try Progrip in Bonnybridge, 1st class.
Best of luck.
Davie
Paul, check the tread depth for difference across that axle in particular - if they are even a couple of mill out it will pull like a bitch!! Had it happen to me - a quick reshuffle of the wheels to match up the depths and all was good again! :icon_salut:
Scary how bad it is eh?
Oh aye baz tuink it cld be that. As its a brand new eagle f1 on the front left and all the rest have been on since i got the car and cpvered about 14,000 miles in the two years nearly. So vey well cld be that. Miht get the old one vulcanised and chuck it back on u til i can get funds for another 3new ones then just do all four at same time
