05WRX Posted August 17, 2011 Posted August 17, 2011 On my way home today decided to give it a bit of welly as i came off a roundabout. Heard a whining noise coming from the turbo and i did not get as much power (boost) as i normally get. I'm guessing a hose may be loose going to turbo?? Car is getting serviced this week but is there anything i can look for at the moment to sort the problem. Cheers.
rig-pig Posted August 17, 2011 Posted August 17, 2011 could be a split or loose hose m8 when is it going in ???
05WRX Posted August 17, 2011 Author Posted August 17, 2011 On 17/08/2011 at 18:29, rig-pig said: could be a split or loose hose m8 when is it going in ??? Car's going in next week for a service. I noticed that the intercooler pipe does not appear to be sitting on the turbo properly. Don't know if this is the problem.
rig-pig Posted August 17, 2011 Posted August 17, 2011 (edited) what time you fin work tomorrow ?? drop past the house and i will have a look for you, bring grass feed lol Edited August 17, 2011 by rig-pig
05WRX Posted August 17, 2011 Author Posted August 17, 2011 On 17/08/2011 at 20:45, rig-pig said: what time you fin work tomorrow ?? drop past the house and i will have a look for you, bring grass feed lol Cheers, i'll pop along at around 1.20. I will bring some grass seed.
subarucraig Posted August 17, 2011 Posted August 17, 2011 hope you get this sorted mate and its just a slack/split pipe theres one in my work just strip that
05WRX Posted August 18, 2011 Author Posted August 18, 2011 Problem solved. Loose intercooler pipe. Cheers Craig.
scooby doom Posted August 19, 2011 Posted August 19, 2011 On 18/08/2011 at 13:22, 05WRX said: Problem solved. Loose intercooler pipe. Cheers Craig. Always good when it's an easy fix I had a similar problem a few months back and couldn't find the problem until I took the intercooler off and found the following damaged and leaking pipe hidden at the bottom of the turbo.
Scottynic Posted August 31, 2011 Posted August 31, 2011 On 19/08/2011 at 21:07, scooby doom said: Always good when it's an easy fix I had a similar problem a few months back and couldn't find the problem until I took the intercooler off and found the following damaged and leaking pipe hidden at the bottom of the turbo. no posted for a while just reading. My turbo hose looks the same as your in the middle, is it supposed to look like it has been patched? ie. like a puncture repair? cheers
WUZ Posted August 31, 2011 Posted August 31, 2011 That patch in the middle of your hose is where a stainless steel metal retaining "t-piece" is placed. It keeps the Jubilee clips in a certain rotation so you can reach it with the screwdriver to fasten/loosen it. It is meant to be there and be like that.
Scottynic Posted August 31, 2011 Posted August 31, 2011 thanks for that, not very pretty tho but I guess if it works that's what matters.
