reako Posted June 26, 2011 Posted June 26, 2011 does anyone know the part number or where i can get the bit of balck plastic that joins from the rear of the sideskirt onto the front of the rear arch for a blobeye sti? dont have a clue what its called and have searched everywhere! cheers!
patsy Posted June 26, 2011 Posted June 26, 2011 A breakers should have something like that going cheap I'd imagine? Try some breakers, before the dealers. I would!
marko72 Posted June 27, 2011 Posted June 27, 2011 Hi. Do you mean this bit? If so then I got a replacement from the dealer. You'll need 2 plastic screwy thingys that the dealer can get for you to hold it on, plus I used a sticky fixer as well i think so it wouldnt come off. Just make sure its the right one for your car as I was sent out one that was too big??? That dealer said 'you might need to bend it too fit in right'. Cleary not right as the holes didnt match up. A differnt main dealer sorted me with the right one for my car. Cheers.
