GazTurboUK Posted January 30, 2011 Posted January 30, 2011 Looking to fit oil pressure and oil temp gauges to my pre-facelift classic, was wondering what people have used/prefer with regards using a sandwich plate or adaptor at oil pressure switch? Also will have three gauges fitted whats the best position/pod for these?
drb5 Posted January 31, 2011 Posted January 31, 2011 For pod, i never found a 3 gauge pod i liked for the dash, so suggest a pillar pod. I've always fitted the pressure sensor at the existing one, as it's simple, easy and CLEAN. Fitting a sandwich plate means changing the oil, but it can get a bit messy. For the temp sensor, i removed the plug to the right(IIRC)ontop of the block, then drilled and tapped a thread to suit.
johnnyr6 Posted February 1, 2011 Posted February 1, 2011 Not bad dave, you? The motor isnt going too well these days as its needing a couple of bits. Mainly needs an engine + box + an interior...lol Johnny
drb5 Posted February 1, 2011 Posted February 1, 2011 Aye no bad....same sh1t, different day. Longing for another scoob, even though i'd never afford bein able to run it. "Updates" coming then i take it? Making it faster than Colins paperweight?
johnnyr6 Posted February 1, 2011 Posted February 1, 2011 I will do a project thread when its nearer the finished stage ( i reckon it'll take me about 2 years or so to build). It wont be faster than colins as i will probably need to use mine as a road car more than him and i dont want to rotate the turbo. I can't start it until i get a couple of bikes sorted and out my garage, so hopefully get back into it in the spring. Johnny
drb5 Posted February 1, 2011 Posted February 1, 2011 Nice one. Always reckoned 450 in a classic, was around the perfect amount of hp for the road. Apologies to the OP for the hijack.
