patsy Posted November 30, 2010 Posted November 30, 2010 My wrx wagon is not slammed totally down, but sits pretty low. About a inch gap from top of tyre to whell arch. I'm wondering if raising my suspension a couple of inch, will affect my geometry much? If I measure the coilover height to start and once the snow is away, lower them back to the same heights as now. Will i still need another geometry setup or will it be okay? My car and tyres seem to be going rather well in this snow, but very nearly risking my front bumper being a plough. Not a good idea with a new fmic is tucked behind it! Worried I'll damage it. Thoughts and past experiences please. Ryan
arch Posted November 30, 2010 Posted November 30, 2010 Changing the ride height will alter the geometry in particular the toe settings which in turn will affect other settings.
mk1cos Posted November 30, 2010 Posted November 30, 2010 ryan, have you piped in the fmic yet or is that ma job?? if not then i would take it off ntil its needed....... less chance of damage in the snow
patsy Posted November 30, 2010 Author Posted November 30, 2010 ryan, have you piped in the fmic yet or is that ma job?? if not then i would take it off ntil its needed....... less chance of damage in the snow That'll be your job sir. Going for reverse inlet manifold, so all that will be plumbed in when my motors with you's. Taking it off did cross my mind, but can't take it off once its a functional part, so was trying to work around it by maybe lifting the suspension up a few inch???
patsy Posted November 30, 2010 Author Posted November 30, 2010 Changing the ride height will alter the geometry in particular the toe settings which in turn will affect other settings. What actual effect will this have. If I lift by a few inch. In a dafty terms please. Ryan
scooby222 Posted November 30, 2010 Posted November 30, 2010 handling will be rubbish and even lowering it back to the same settings again would need a geo setup im afraid
craigdmcd Posted November 30, 2010 Posted November 30, 2010 handling will be rubbish and even lowering it back to the same settings again would need a geo setup im afraid Why would you believe this. Once the springs are returned to their original position, everything sits exactly as it was - I know this through actual experience of carrying out this procedure.
scooby222 Posted December 1, 2010 Posted December 1, 2010 ok i stand corrected, that was just my understanding - so itd be ok to raise them up for a few months them drop them back down to the original height without having the geometry done, as per the op query? not something id have considered doing but then i dont work on these things myself so happy to take expert knowledge
patsy Posted December 1, 2010 Author Posted December 1, 2010 To be honest, think I'll raise her a bit and try putting things back to original heights in a bit. Getting about just now, out weighs any damage or a £60 geometry setup again in spring time. Need somewhere dry to do now but! Sitting in the street with this snow is not very good.
mk1cos Posted December 1, 2010 Posted December 1, 2010 To be honest, think I'll raise her a bit and try putting things back to original heights in a bit. Getting about just now, out weighs any damage or a £60 geometry setup again in spring time. Need somewhere dry to do now but! Sitting in the street with this snow is not very good. drive into one of the indoor car parks
patsy Posted December 1, 2010 Author Posted December 1, 2010 My thoughts exactly! On the hunt tonight for a space to get her jacked up in reasonable comfort. Ryan
arch Posted December 1, 2010 Posted December 1, 2010 Why would you believe this. Once the springs are returned to their original position, everything sits exactly as it was - I know this through actual experience of carrying out this procedure. You will never get them back to exactly where they were before moving them no matter how closely you mark them but for road use it would probably be close enough ish depends how carefully you mark them.
patsy Posted December 1, 2010 Author Posted December 1, 2010 You will never get them back to exactly where they were before moving them no matter how closely you mark them but for road use it would probably be close enough ish depends how carefully you mark them. Going to measure between top and bottom nuts. Not sure what to call them, but should get it back to within 1mm of where it is now. Is there anyway I can adjust the toe a little to try and compensate, it won't be real tyre scrubbing stuff will it? Ryan
craigdmcd Posted December 1, 2010 Posted December 1, 2010 You will never get them back to exactly where they were before moving them no matter how closely you mark them but for road use it would probably be close enough ish depends how carefully you mark them. Well, years of moving the heights up and down on a Group A Impreza and a modified Group A Mazda 323 soon taught us that it when you put it back to where you were, you weren't far enough out of your settings to be concerned about. Patsy, the best way is to mark the struts with a touch up paint where the adjusting collars are at present, and then move it up, then you can wind them back down to the exact height. As for geometry, just get a cheap tracking check done, which won't really be that far out, and when you lower it again, just get the tracking done again. The camber won't change enough with a couple of inch height change to massively upset the car, especially given the conditions we are having to drive in.
patsy Posted December 1, 2010 Author Posted December 1, 2010 Nice one. Thanks for your confident reply Craig. Ryan
patsy Posted December 3, 2010 Author Posted December 3, 2010 Adjusted my front 2 coilovers up 50mm more between adjusting collars. Gives plenty more front spliter clearance now. Left back end as it was, sits a wee bit odd, but for a good reason. No where near as much scraping noises from underneath and I'm not ploughing the mound of snow in the centre of the roads anymore! FMIC safer for the time being. Lol.
