frankyboy Posted June 30, 2010 Posted June 30, 2010 done a flash test on my classic and it has shown a fault with the icv can this be cleaned or will it need to be replaced
john_stevenson2 Posted June 30, 2010 Posted June 30, 2010 Mark the position before you remove, make a carefull note of the order and direction of the one way valve. Can be cleaned using brake cleaner.
frankyboy Posted June 30, 2010 Author Posted June 30, 2010 Mark the position before you remove, make a carefull note of the order and direction of the one way valve. Can be cleaned using brake cleaner. mark the position where the 2 screws are on top of the valve
jae Posted June 30, 2010 Posted June 30, 2010 mark the position where the 2 screws are on top of the valve just unscrew but be careful that the end doesn't fall off, that happened to me and had to buy a replacement from a breakers. and yes just use brake cleaner don't be too rough on it.
frankyboy Posted July 1, 2010 Author Posted July 1, 2010 tried to take out the 2 screws on the top of the icv and im just chewing the screw can i take of the whole unit to clean
kennyuk300 Posted July 1, 2010 Posted July 1, 2010 tried to take out the 2 screws on the top of the icv and im just chewing the screw can i take of the whole unit to clean Here you go Frankyboy....... http://forums.nasioc.com/forums/showthread.php?t=781242 Kenny
frankyboy Posted July 1, 2010 Author Posted July 1, 2010 Here you go Frankyboy.......http://forums.nasioc.com/forums/showthread.php?t=781242 Kenny cheers kenny funny enough after i took the icv off and realised it had a gasket a thought i should replace it so have phoned subaru and ordered 1 prob have to get it sent over from japan again and take another 6 weeks lol
