stev555 Posted May 25, 2010 Posted May 25, 2010 Hi need to top up my brake fluid,would it be ok to use dot4,went to halfords,they said it should be ok,but it says dot3 on the cap,not to sure cheers steven.
euan_r Posted May 25, 2010 Posted May 25, 2010 yes. dot 3,dot 4, dot 5.1 are same fluid type but with higher boiling points up the range. ive always used 5.1 personally. just under no circumstances use mineral or silicon (dot 5).
