frankyboy Posted May 23, 2010 Posted May 23, 2010 alright guys my car is starting to play up again its struggling to start when cool and the revs are eregular droping up and down. somebody mentioned it could the the crank sensor. i have just put new plugs in and they still seem fine so any suggestions
giz1978 Posted May 23, 2010 Posted May 23, 2010 hi, poor start then rough running doesn't sound like crank to me, like sticking stepper.get it pluged in
frankyboy Posted May 23, 2010 Author Posted May 23, 2010 hi,poor start then rough running doesn't sound like crank to me, like sticking stepper.get it pluged in its to old to get plugged in lol need some1 who knows about the flash test what is a sticking stepper??
giz1978 Posted May 23, 2010 Posted May 23, 2010 it is a little valve which controls your idle below 1200 rpm and sets the amount of air needed to start and control your idle i.e if your car is warm it will be 75% ish out but if it cold it will wind in upto 75% ish. This is controled by the ecu off your water, air sensors,map and maf sensors. if it is sticking it will not be able to adjust right so consently trying to compensate so giving you a un even idle and poor start from cold but clears when the rev are taken above 1200rpm hope this helps a bit o cranks sensor just break down sometimes you can tapp them and it works for a bit then breaks again as it a magnet and wire wrapped around it.
