scamb3 Posted March 31, 2010 Posted March 31, 2010 Took the car for a drive yesterday and was boosting fine. Tried to accelerate in 5th gear doing about 70 at the was no boost. Pulled the car over to see if any pipes had popped off, couldn't see any but noticed the dump valve was stuck open. took the car home and put the original valve back on. When i took the car back out the car still had no boost. There was no smoke or any dodgy noises coming from the car. Has my turbo gone or could i have a problem with my actuator or wastegate? Any ideas? cheers scott
Big 'D' Posted March 31, 2010 Posted March 31, 2010 Took the car for a drive yesterday and was boosting fine. Tried to accelerate in 5th gear doing about 70 at the was no boost. Pulled the car over to see if any pipes had popped off, couldn't see any but noticed the dump valve was stuck open. took the car home and put the original valve back on. When i took the car back out the car still had no boost. There was no smoke or any dodgy noises coming from the car. Has my turbo gone or could i have a problem with my actuator or wastegate? Any ideas?cheers scott Have you got zero boost or just less boost than normal ie running on wastegate pressure alone? Cheers Iain
scamb3 Posted March 31, 2010 Author Posted March 31, 2010 The boost kicked in a couple of times but getting no boost at all now
Big 'D' Posted March 31, 2010 Posted March 31, 2010 The boost kicked in a couple of times but getting no boost at all now Have you got a boost gauge fitted? Cheers Iain
scamb3 Posted March 31, 2010 Author Posted March 31, 2010 I got one last week but its not plumbed in yet.
Big 'D' Posted March 31, 2010 Posted March 31, 2010 I got one last week but its not plumbed in yet. Shame, it sounds like your boost solenoid might be playing up only letting you boost to wastegate pressure. Cheers Iain
scamb3 Posted March 31, 2010 Author Posted March 31, 2010 where is the boost solenoid located? thanks for your help iain
Big 'D' Posted March 31, 2010 Posted March 31, 2010 On the drivers side wing mate, what year of scoob do you have?
scamb3 Posted April 1, 2010 Author Posted April 1, 2010 it's a 95 type ra. Had the turbo off today and its fooked. what would be the best turbo to get for it?
Big 'D' Posted April 1, 2010 Posted April 1, 2010 it's a 95 type ra. Had the turbo off today and its fooked. what would be the best turbo to get for it? What did you find wrong with it fella? Cheers Iain
Big 'D' Posted April 1, 2010 Posted April 1, 2010 the blades make about a 1/4 turn then jam. OH that would defo stop your boost, any change in turbo would require a remap or boost control at the very least mate. Cheers Iain
scamb3 Posted April 1, 2010 Author Posted April 1, 2010 got a few other thing to put on the car. front mount intercooler and bigger injectors. should i get the same turbo or go for something bigger?
Big 'D' Posted April 1, 2010 Posted April 1, 2010 got a few other thing to put on the car. front mount intercooler and bigger injectors. should i get the same turbo or go for something bigger? Depends on what you want from the car, top end power, all out acceleration or a mix of both Cheers Iain
scamb3 Posted April 1, 2010 Author Posted April 1, 2010 a bit of both. dont want to much power would like about the 340 mark.
Big 'D' Posted April 1, 2010 Posted April 1, 2010 a bit of both. dont want to much power would like about the 340 mark. Vf34 or 35 then mate or perhaps another TD05. Cheers Iain
Jon B Posted April 2, 2010 Posted April 2, 2010 Vf34 or 35 then mate or perhaps another TD05.Cheers Iain probs go for vf35 let us know what you go for ya gonna need a remap after gettin front mount done so you may as well do a few mods at once
Big 'D' Posted April 3, 2010 Posted April 3, 2010 The VF35 may need a little work to avoid getting boost creep, but its worth it Cheers Iain
