irish al Posted February 2, 2010 Posted February 2, 2010 If I remove the complete heater matrix unit from a car does the flow and return water pipes from the engine need to be connected to retain water flow or can they be individually squeezed off. Al
Jon B Posted February 3, 2010 Posted February 3, 2010 i would say connect them together though don't quote me on that......
badbaz Posted February 3, 2010 Posted February 3, 2010 Either way will do, is this a permanent removal?
irish al Posted February 3, 2010 Author Posted February 3, 2010 Yes, permanent removal. Probably a stupid question but I have no engine knowledge at all. Will clamp them as thats easier Thanks, Al
badbaz Posted February 4, 2010 Posted February 4, 2010 If it's permanent then link them, closer to their origin at the engine side, you don't want air trapped in the pipes though I suspect it wouldn't do any harm. Follow the pipes that are there, you'll probably be able to use them to complete the join up!
