Auldy Posted January 17, 2010 Posted January 17, 2010 Hi guys looking for some help if possible please. Cars turning over and getting spark etc, but found out that its not pumpin fuel through to the engine. Just wondering if theres a fuel relay/fuse that i can check? is it possible that the pump has just packed in or there some other reason/common fault that i may overlook? if someone could point me in the direction of fuel relay/fuse so i can check this first that be great. Scoobs a 99 V5 wrx sti - import Thanks Stuart
RA Dunk Posted January 17, 2010 Posted January 17, 2010 Can you hear the pump priming when you turn the key?
Auldy Posted January 17, 2010 Author Posted January 17, 2010 RA Dunk said: Can you hear the pump priming when you turn the key? nope cant hear it, only thing i can hear is boost soleniod clicking when turning on ignition.
james666 Posted January 17, 2010 Posted January 17, 2010 if you cant hear pump then i would say your pump is gubbed!!!! go for a walbro 255, but take pump out and test it first
