Wee Jock Posted January 5, 2010 Posted January 5, 2010 Tried this on strictly technical to no avail, hope someone on here can help! How easy is it to change the w5w sidelights on a Hawkeye? Is it a garage job? Any pointers would be appreciated. Thanks in advance Wee Jock
Ian Coulter Posted January 5, 2010 Posted January 5, 2010 Wee Jock, I looked into this when I first got my car, as I wanted to change the bulbs to something a bit more blue to match the HID dipped beam. Apparently, you have to separate the clear plastic lens from the main unit by heating the seal with a hairdrier. You then have to be very sure that you get it all sealed up again after changing the bulbs. The manual says to take it to the dealer to change the front bulbs. I never did get around to changing mine. Maybe one day ... Regards, Ian
Wee Jock Posted January 5, 2010 Author Posted January 5, 2010 (edited) Wee Jock,I looked into this when I first got my car, as I wanted to change the bulbs to something a bit more blue to match the HID dipped beam. Apparently, you have to separate the clear plastic lens from the main unit by heating the seal with a hairdrier. You then have to be very sure that you get it all sealed up again after changing the bulbs. The manual says to take it to the dealer to change the front bulbs. I never did get around to changing mine. Maybe one day ... Regards, Ian Cheers Ian, just bought these PIAA H520 Tera Evolution 6000 LED Sidelights, just installed them in my Shogun and they are awesome but expensive, got a set for the Scoob as I was that impressed, guess ill drop Scoobyseller a line. Any joy with yer wheels? Regards Paul Edited January 5, 2010 by Wee Jock
G.Mac Posted January 5, 2010 Posted January 5, 2010 If the hawk is like the blob you will need to remove the headlight to get into the sidelight holder, bit of a crap design
