Bc's And Whiteline Gear Fitted.
Not sure I agree that point.....
Surely if you wind the hub up or down on the strut the geometry of the control arms is going to change?As a minimum I'd expect that to effect toe in / out.
The BC instructions also say that when adjusting ride height you need to loosen the two bolts which attach the strut to the hub, that will certainly effect camber!
Aw shucks - sounds like I've been misuninformed again ;)
Next you'll be telling me that I shouldn't be using Ragu to flush out my engine oil...
