scooby222 Posted November 15, 2009 Posted November 15, 2009 i appear to have a leak from my rear caliper,the seal where the brake line goes into the caliper has been replaced but a few pumps on the pedal and brake fluid pisses out the bottom of the pad onto the disc. its losing quite a bit which is obviously making it an issue to drive to a garage... getting really fed up with this as im only home at weekends to try and sort it,any ideas people? o yea, cars an 05 sti, rear brembo caliper
euan_r Posted November 15, 2009 Posted November 15, 2009 (edited) you need to get a proper seal kit min. suprised at such a young car needing them done but then again ive seen your driving. oh aye there should be two copper washers one either side of banjo fitting too. i would have replaced the seals to you if you wanted but its a fair distance awa. edit: your needing these: rear brembo seals Edited November 15, 2009 by euan_r
scooby222 Posted November 16, 2009 Author Posted November 16, 2009 cheers Euan, might need to call on you yet.... have someone down here to look at them for me but not sure whether the seal kit would work or if im better to bite the bullet and get a new caliper
