Fuel Pump
t5d5
hi guys im new on here and have a 1996 wrx import, really need help with the car. i think the fuel pump has gone on it as it will turn over but wont start, put power to it using a power probe and nothing. Also removed the block under the back seat as i was told to do so by sva.
does anyone have a working fuel pump, doesnt have to be uprated any help would be great cheers
darrell
darrell
Try running a new earth in from the fuel pump to the battery, that was the problem I had with mine, if it still won't work, I have a spare here somewhere ;)
Pele
No i havent got an induction kit, car is completly standard . what wire do i need to earth . i have a power probe so i can earth it out with that to see if it works
cheers for the help i have no idea about car electrics
I just used a length of wire from an old flex cable to test it lol, just literally ran it from the battery to the pump to make sure that was the problem then added a new piece under the seat which was where it had burnt out the connector box.
i have removed the box under the seat and bridged all the wires as told to do so by sva, gutted though car has sat now for two months coz of this hate just looking at it lol
When you switch on the ignition can you hear the pump prime?
no nothing at all not even sort of a noise. taken the fuel filter off to and there isnt any fuel in that either
hi mate you sure theres petrol in the tank?? ;)
its got to be the fuel pump then,no sound the petrols not priming
gutted. any one got one im in ashford kent
any one no if this will fit on mine ;)
if its any help i know if you can buy the uprated fuel pump witch you get
normally with ppp, the pump fits from 92 to 00 you can buy a walbro
one for around £80 new or even cheaper :lol:
Edited by col_2
You are more than welcome to try the one i have
that would be good please mate how much you want for it if it works
