Iacv Part Numbers
Anyone know part numbers for IACV for new age (03) Wrx Sti?
Cheers.
Assuming yours is mounted on top of the throttle body it should be either 22650AA181 or 22650AA182 and the gasket is 22659AA120 or alternatively try this generic part number:- 123DONTBESOLAZY33ANDTAKEYOUR67CHASSISNUMBER2YOUR DEALER23ANDASKTHEM666 :thumbup:
there not cheap either, be prepared for a shock :thumbup:
try to clean your current one with brake cleaner 1st as some times they are just clogged up with crap.
Also have fun trying to get the gasket back in !!!!!
Remove when car is cold / remove coolant cap 1st to make sure no pressure in coolant system as the idle control valve is water fed and if water gets into your throtle body then you could be in a bit of trouble.
  • 2 weeks later...
managed to get a replacement one for £70 off 05 plate that only done 20k so im happy.
Good Effort, did it sort you problem? Can I ask where you managed to source this from as mine seems to be knacked also... :whistle:
