Fault Code1131
my reader picked up the 1131 code(obd11) Front oxygen sensor circuit malfunction (short circuit)
is it just(wallet twitches) a replacement needed or is there a possibility of a wiring fault....with the mention of short circuit :lol:
ta,Colin
ta,Colin
Col,
Are you still fannying around with this :thumbup: I would suggest that it needs replaced dude...give Ian Grieve's a phone or Hypertech as they will give you a price for a new one.
IIRC they arent hugely expensive. :angry:
PS that wallet twitches when someone mentions "its your round" ;) ;)
Edited by Gus the Bus
  Gus the Bus said:
Col,
Are you still fannying around with this :lol: I would suggest that it needs replaced dude...give Ian Grieve's a phone or Hypertech as they will give you a price for a new one.
IIRC they arent hugely expensive. :)
PS that wallet twitches when someone mentions "its your round" :beer::P
£290 and thats fi the local motor factors ! keep my eye on ebay i think for a few weeks at least.
Are the front and rear sensors the same ?
Edited by CJK
:P thats daylight robbery!!!! the last one I bought was £69 IIRC :lol:
Mind you, if its sorts the problem then I'd be biting the bullet. :)
Have you thought about the fact that with this code the car might be running in "limp mode" hence why you are getting little boost!!?
  Gus the Bus said:
:beer: thats daylight robbery!!!! the last one I bought was £69 IIRC :lol:
Na Gus,its still a quick ish motor comparing to n/a cars,obviously its not running how it should with a duff oxy/lambda sensor.How does yours feel coming on boost...is it a defo shove in the kidneys or what? :P
  CJK said:
Na Gus,its still a quick ish motor comparing to n/a cars,obviously its not running how it should with a duff oxy/lambda sensor.How does yours feel coming on boost...is it a defo shove in the kidneys or what? :lol:
Not quite as oooyaaa as the Impreza but not far off :P
I'm saying about the "limp mode" because I know when the one time the Fozzy threw a code there was deffo a significant drop in boost until I flashed the code :)
