Ride Height Help
I'm in the middle of stripping my oe suspension to make room for my new bc coilovers. I'm after someone to suggest what height I should be setting them at. As in a size from wheel centre to wheel arch! My car is a new age wrx wagon. I hope someone understands what I'm meaning!
Ta
My mate fitted his BC's straight as they came out of the box and they were too low and needed adjusting up.
5 full turns of the strut is 1 inch so i would give them at least 5 full turns before fitting.
The spring rate comes set up so just leave it as it is for now.
And 10 clicks from soft seems like a good damping rate on mine for every day driving.
When i fitted mine i adjusted them down till the scrubbed on hard cornering and then would them up a couple of turns
and it seems to be fine apart from speed bumps ;)
Ta
hi bud try around 62 to 63 cm from ground to wing lip that what i set them at ,check the clearance at the rear between the adjusting collar and tyre wall inner ,thats with 17in 215/40 /17 tyres
cheers geo
gp motorsport
Edited by cusco kid
Will measure mine when I get home from work for you tomorrow but thats on 18inch wheels ;)
That would be great, I'm on 45/17's.
Mine WRX 06 on 18'' wheels, F 320mm R 300 mm from centre of wheel
I drive on rough roads and the handling is great ;)
Edited by zarabad
