Head Gasket Torque Settings
Hi all
I'm just about to replace the head gasket on my scoob; does anyone know the torque settings? It’s an EJ20K engine.
Also what would be the general recommendation...oe or aftermarket gaskets?
Andy
Hi all
Andy
hi this is what auto data recomends. its the software we use in our garage
Tighten in the following stages:
1) 29 Nm
2) 69 Nm
3) Slacken bolts by 180°
4) Slacken a further 180°
5) Bolts 1 and 2 to 34 Nm
6) Bolts 3 - 6 to 15 Nm
7) Tighten all bolts by 90°
8) Tighten a further 90°.
They also show a pic of the sequence you should follow I cant get it to copy so al try to explain,
1st tighten the 2nd in at the top (middle bolt)
2nd tighten middle bottom
3rd tighten the top closest to the front
4th tighten bottom near the rear of engine
5th tighten front bottom and
6th tighten top back near rear of engine
its the same for both sides
hope thats easy to understand basically the middle 2 first then front to back in a x pattern
Edited by camcq
