BLUE V LTD Posted February 28, 2009 Posted February 28, 2009 Need help. what is the sensor in the bottom of the down pipe on a classic with a cat fitted.
Big 'D' Posted February 28, 2009 Posted February 28, 2009 Need help. what is the sensor in the bottom of the down pipe on a classic with a cat fitted. Post cat exhaust temp sensor, you do not need it and car can be run with it unplugged without CEL. Cheers Iain
col_2 Posted February 28, 2009 Posted February 28, 2009 Post cat exhaust temp sensor, you do not need it and car can be run with it unplugged without CEL.Cheers Iain your spot on, you dont need it on the early classics, but you do need it if the sensor is at the top near turbo on the later classics, thanks to simon (jollygreen) for the info
BLUE V LTD Posted March 1, 2009 Author Posted March 1, 2009 (edited) your spot on, you dont need it on the early classics, but you do need it if the sensor is at the top near turboon the later classics, thanks to simon (jollygreen) for the info Cheers for the help col, sorry to phone you out of the blue. next time i see you i'll get the once again thanks for the help. Edited March 1, 2009 by BLUE V LTD
Deano 666 Posted March 1, 2009 Posted March 1, 2009 Cheers for the help col, sorry to phone you out of the blue. next time i see you i'll get the once again thanks for the help. whats up matt??
