Dump Valve Not Dumping
On the way home from Santa Cruise dump valve has stopped making a noise. HKS one that makes a loud blow off, had developed a slight chirp after last trackday but never thought much about it.
Car still ran fine but concerned if it isn't opening that I will be doing damage. Also can you get servicing kits for these or is it buy a new one?
Get a blanking plate on, even off boost it sounds ace, will get a wee clip up of mine once i have been mapped and able to give it some beanz.
But just now, whip the dumpvalve off and give it a good clean with carb cleaner, then a good spray with wd40 and see if that helps.
All the best
Graeme
Serve your right for blowing all my tinsel away with your stupid exhaust! :lol:
my HKS SSQV done the same too a wee while back.
took it off and opened it up, cleaned / lubricated with some spray lithium grease (says on tin for lubricating springs) from halfords,
hey presto, as good as new :P
I the vac hose still connected? mine did this when fitting mine. The feedback pipe was slightly to short and burst in my first drive and that exactly what it did
