cusco kid Posted December 11, 2008 Posted December 11, 2008 here is the latest mods to track car guys ///fuel system we are running red top pump low pressure to the swirl pot fed from tank with modified pick up pipe the swirl pot then feeds the high pressure pump ,first through a merc filter then to the fuel rail we have fitted an alloy firewall for safety, and the aircraft spec hoses are then coupled through the f/wall on high pressure connections (piccs to be taken the pump is a sytec mounted on a c class fuel pump bracket with rubbers to combat vibration problems good old mercedes parts all the fuel system parts are rubber mounted SUSPENSION MODS TO REAR we have fitted adjustable whiteline track(PINK) (powered coated by us at Williams powder coating ) arms to allow us to increase the track width ,verus competion coil overs were the first mod before we stripped the car down to mod for the track/ sprint/ hillclimb . we were impressed with the handling from the start. buy playing with bump and rebound,then adjusting the crossover settings the handling just got better and better with no sacrifice in ride quality..here is some piccs first step was to remove the old track arms //the long bolt through the hub that locates the track arms were fooooooookin tight they wee japs can tighten nuts the toe adjusting bolt thar subaru use to adjust tracking this will be deleted fr a toe lock kit bolt type an tracking is carried out on the new track arm adjusters.the inner bolt is still used to locate the arm we then removed the radius arms ,again bolts were tight so i removed the chassis mounting brackets(3bolts ) so that i could then get them in the vice to slacken the long location bolts the new poly sus/bushes to be fitted in the hub carrier and radius rod after p/coating the new bars fitted alloy d/links and stout mount kit 27mm on,all bushes lubed all bolts coppersliped to ease strip down later kev and i had already fitted poly bushes to the diff xmember this stops the x member banging //movement against the chassis on quick up shifts and downshifts that all for to-nite more piccs and our mods at the weekend geo
Guest CRAIG D Posted December 12, 2008 Posted December 12, 2008 (edited) IMPRESSIVE Loving the pink Iv got the pink sti one's on the back of mine Cusco kid do you get decent discounts on the poly bushes?? Edited December 12, 2008 by CRAIG D
jimser Posted December 12, 2008 Posted December 12, 2008 looking good geo,when you hoping to have it up and running?
cusco kid Posted December 12, 2008 Author Posted December 12, 2008 looking good geo,when you hoping to have it up and running? new year jim ,can come quick enough m8 ...how are you bud
cusco kid Posted December 12, 2008 Author Posted December 12, 2008 IMPRESSIVELoving the pink Iv got the pink sti one's on the back of mine Cusco kid do you get decent discounts on the poly bushes?? i like sti pink also /// powder coating done to stop corrossion on the parts m8 ,just so happens i did them pink geo ps i aint gay ,ask my boyfriend lol
colin_ross Posted December 12, 2008 Posted December 12, 2008 George, do you not feel that the banjo bolts will restrict the flow of fuel? How big are the holes through the bolts? Nice looking hardware BTW
frank c Posted December 12, 2008 Posted December 12, 2008 Looks like it's coming along nicely George.. I'm sure it'll be worth the wait Have you got much more to do ? ps: How's your sons type r (?) Has he been doing anything else to it recently.. It's was looking the dogs danglies the last time he posted a few pics.
cusco kid Posted December 12, 2008 Author Posted December 12, 2008 Looks like it's coming along nicely George.. I'm sure it'll be worth the wait Have you got much more to do ? loads m8 that why we are working flat out on it ps: How's your sons type r (?) Has he been doing anything else to it recently.. It's was looking the dogs danglies the last time he posted a few pics. he has fitted verus coil overs(race type ,but not much more geo
cusco kid Posted December 12, 2008 Author Posted December 12, 2008 George, do you not feel that the banjo bolts will restrict the flow of fuel? How big are the holes through the bolts?Nice looking hardware BTW when i had my 3door cossie rally car with 350 bhp i had much the same set up without any probs so time will tell m8the bolts have been relieved inside to give more flow geo
craigdmcd Posted December 12, 2008 Posted December 12, 2008 George, do you not feel that the banjo bolts will restrict the flow of fuel? How big are the holes through the bolts?Nice looking hardware BTW That looks more than a little bit like the pump assembly and filter from a older Merc, and was used on models right up to the 6.0 V12 IIRC, so flow shouldn't be too big of a problem.
~ ~ Cal ~~ Posted December 13, 2008 Posted December 13, 2008 Awesome indeed ! I like the Alistair Darling style "spend our way out of the credit crunch" assault on this car ! Always welcome luxurious spending on this forum. It's sheer indulgence
