Connections For Dccd
Guest CRAIG D
Guest CRAIG D
AFTERNOON,
Just fitted the diff and prop shaft and am about to fit the gearsbox but its a dccd type. Are the connection for the dccd on the outside or inside of the shell and how many connetcions are there.
Any pics would be good if not then am sure it could work it out :driving:
:rotfl:
I seem to remember there is a multi plug connector that will run to the dccd ecu in the car. That in turn runs to the dash and controller connections. John St has removed more than a couple so may be able to help with the finer points.
Guest CRAIG D
i can see all the wiring inside the car but dont seem to see any of it outside. :driving:
Guest CRAIG D
Also having probs with the mounting of the gearbox.
Here is what i have.
1, Top gearbox mount
2, Iv got the H type frame that sits under neath the box
but as far as i can see thats it. Is there anything missing?? There seem to be bolts on the gearbox that sit just under the H frame but they dont seem to go anywhere??
This is the prob when you buy a car in bits :driving:
Edited by CRAIG D
Guest CRAIG D
DOH
I was missing an engine mount which iv found so its fiited. it will come off again once i get a the group N mounts.
Still cant match up and the plugs from the gearbox tho which is a pain in the ass.
