stuarted Posted November 5, 2008 Posted November 5, 2008 Right chaps, looking for advice. I know the Z32 is the nissan 300ZX MAF. What is the Q45? I'm running an Apexi Power FC ECU and am aware i'll need a re-map. Had a few near catastrophic MAF failures and i'm sure you'll know the MAF for the P1 is pretty fragile. Just want to know whats involved, anyone done it before, costs? Thanks in advance
phil_g Posted November 5, 2008 Posted November 5, 2008 (edited) Nissan Skyline Q45 Air Flow Meter Mass 90mm Sensor http://forums.sidc.co.uk/index.php?showtop...p;hl=nissan+maf Edited November 5, 2008 by phil_g
gambler Posted November 7, 2008 Posted November 7, 2008 I fitted the z32 maf. Was a straight bolt on. Just needed to switch over a couple of wires. When i got them maf sent i made sure it had the connector still attatched. Whole thing took about 20 mins to do. I got the wiring from a guy from 22b.com Jolly green monster i think
stuarted Posted November 7, 2008 Author Posted November 7, 2008 cheers chaps, do either of you know if the P1 is the 80 or 90mm item?
