eureka Posted September 3, 2008 Posted September 3, 2008 can anyone help i was just browsing for a apexi fc ecu for sooz,s car and noticed that on some ads it says for uk models only does this make a difference to the map or just the fitting to uk spec loom and where is the best place to buy one of these as will need one soon so i can send to zen for a my 18g turbo to be fitted and a fresh set of injectors its a v3 type r v limited 97 thanks answers on a postcard to !!!
emoe Posted September 3, 2008 Posted September 3, 2008 can anyone help i was just browsing for a apexi fc ecu for sooz,s car and noticed that on some ads it says for uk models only does this make a difference to the map or just the fitting to uk spec loom and where is the best place to buy one of these as will need one soon so i can send to zen for a my 18g turbo to be fitted and a fresh set of injectorsits a v3 type r v limited 97 thanks answers on a postcard to !!! The UK spec and the JDm have a couple of wires in different places. You can fit the JDM to a UK but you need to swap some wires on the loom. Dont ask how i dont know!!! Just watched Paul at ZEN do it on mine!
eureka Posted September 3, 2008 Author Posted September 3, 2008 The UK spec and the JDm have a couple of wires in different places. You can fit the JDM to a UK but you need to swap some wires on the loom.Dont ask how i dont know!!! Just watched Paul at ZEN do it on mine! cheers mate he will be doing it antway
emoe Posted September 3, 2008 Posted September 3, 2008 cheers mate he will be doing it antway If PAUL is doing the install then get the Apexi from him, you know then its the right one.
eureka Posted September 3, 2008 Author Posted September 3, 2008 If PAUL is doing the install then get the Apexi from him, you know then its the right one.did think that will call him when were you there
