scoobyit Posted May 12, 2008 Posted May 12, 2008 As above mates 05 WRX is feeling a little down on power... he has put in standard petrol for the last couple of tanks I am guessing that this is the issue, however want to make sure I ain't feeding him pish I drove the car back to back with my 05 WRX and it did feel like the turbo was not giving the kick that I get... Is there anything else that may cause this other than him being a class 1 prat and using cr@p fuel?? Cheers Scott
speech Posted May 12, 2008 Posted May 12, 2008 (edited) I would say quite possibly the fuel. I have a MY03 (blobeye) WRX and on the inside of the fuel flap there is a sticker that says "98 RON MINIMUM", and this is on a UK car. I have always filled up with V-Power or Tesco 99 and once when I was away with work the wife put in standard and said it didn't sound right and didn't feel like it did before. When I got home it was nearly empty so filled back up with the good stuff and it was fine. Run a few tanks of V-Power/Tesco 99 and then see how it's going. Edited May 12, 2008 by Speech
tommo9375 Posted May 12, 2008 Posted May 12, 2008 Hi mate, I had this problem not so long ago and it's because i used 95ron fuel- this was all i could get during the 'panick buying ' of fuel.Put in a tank full of Super unleaded and the car was running as it should be.
scoobyit Posted May 12, 2008 Author Posted May 12, 2008 thanks guys, you have confirmed my thoughts, I shall call him and tell him to wise up and use decent fuel!
