strapper Posted May 5, 2008 Posted May 5, 2008 would an induction kit bring these faults up? The car had a kit fitted then put back to the standard airbox. Any suggestions?
scoobzie Posted May 6, 2008 Posted May 6, 2008 try this m8 it give you the trouble codes http://www.scoobypedia.co.uk/index.php/Kno...CodeDefinitions
strapper Posted May 6, 2008 Author Posted May 6, 2008 I,ve done a full reset and the cel light eventually came back on
scoobzie Posted May 6, 2008 Posted May 6, 2008 how is the car running is the speedo working or is it holding back anywere in the rev range
GalaGogsie Posted May 6, 2008 Posted May 6, 2008 Hi mate Regarding the ICV i removed mine and found that the O ring in the valve had disintegrated so i replaced it and that solved that problem.
strapper Posted May 7, 2008 Author Posted May 7, 2008 Silly question, is the o ring rubber? Going to take it off on saturday and have a look. Done a search and this seems to be quite a regular occurance on imprezas.
strapper Posted May 7, 2008 Author Posted May 7, 2008 also if this idle valve failed or was sticking would it make a ticking noise?
GalaGogsie Posted May 7, 2008 Posted May 7, 2008 also if this idle valve failed or was sticking would it make a ticking noise? Yeah the o ring is rubber mate, you should see it when you remove the valve.
seafar99 Posted May 7, 2008 Posted May 7, 2008 An 'o' ring replacement can be bought from any decent plumbing merchants for the princely sum of 10p.
