Fault Code Help
been getting the 32 sensor coming up for a while now but car is having no issues with it, drives normal, passed emissions test for mot no problem so i have just been resetting it.
went for a run to penicuik to the off road center at lamancha last sunday and drove car from dundee there and back without problems or without cel coming on, not moved car all week and when i started it today the cel light would not go off. getting the knock code now after checking.
any ideas why the knock sensor is coming on after the car was fine on the run and its just been parked up all week?
also any ideas why i'm getting the 22 code? car runs perfect so dont think its the maf and passed mot so dont think its the lambda sensor
cheers for any help :rolleyes:
Yeah 22 is knock sensor I think, 23 is MAF... thats without checking though...
Just try to reset your ECU if you have a classic... You may find that it just clears...
(I had a Knock sensor fault code a few weeks ago, just reset the ECU and then it was fine....)(before I reset, the engine was reigned back because of the fault code...)
